IH Model 35 Rake
Part Time Pete
08-20-2014 04:52:32
I have an IH model 35 rake with rubber teeth. As they go bad, I would like to replace them with steel teeth. Are they interchangeable?
Thanks
Pete
Part Time Pete
08-21-2014 09:06:11
 Re: IH Model 35 Rake in reply to Part Time Pete, 08-20-2014 04:52:32
Bret
I think you're right. I tried the steel teeth and they bolt on fine except for the ones next to the strippers - those one rub.
I didn't think to check if they can be relocated. I'll check tonight
Thanks
Pete
Part Time Pete
08-20-2014 09:10:17
Thanks - I'll check it out. i haven't had it long but it seems to be a well built rake
Pete
Bret4207
08-20-2014 16:45:19
 Re: IH Model 35 Rake in reply to Part Time Pete, 08-20-2014 09:10:17
Some of those IHC rakes you have to change the stripper location between rubber and steel teeth, or so the manual says.
DeltaRed
08-20-2014 06:15:32
Yes.But you will need the hold down clip.I use the 'universal' rubber tooth from Shoup.A bit different,but a lot cheaper and work just fine.Btw,I have both 35 and 15 rakes,same will work on both.
