Chain again
Dave H (MI)
05-02-2014 19:38:06
Just making sure before I buy, is the TSC #40 and #50 chain actually 2040 and 2050? I did see one box that said 2040 on it and it was in the stack with the #40 chain. I think it's the same but...
Dave H (MI)
05-03-2014 13:46:41
 Re: Chain again in reply to Dave H (MI), 05-02-2014 19:38:06
Got it, found both at TSC and got my dry fertilizer working again. Appreciate the help!
Leroy
05-03-2014 05:51:25
the 2040 is same size as 40 except that one link of 2040 is the same lenght as TWO 40 links. In other words they are a double pitch chain and pitch is the length of link between center of roller pins. A 2040 chain will work on a sprocket designed for 40 chain but will use every other tooth, it will not work the other way around as the tooth for the 2040 is like filling up that empty tooth in previous situation so no place for that roller to fit.
JMS/.MN
05-02-2014 19:46:32
Not the same. 20xx is a longer link than the 40/50.
