Ford 309 Corn Planter....
dave404
04-19-2014 05:15:22
I bought my neighbors 309 , it has the fert. box but the auger is frozen up. ive removed hopper and the 3 bolts per side.
ive soaked it with pv blaster but still frozen.
im about afraid to heat it and damaging the fiberglass hopper.
dave404
04-20-2014 17:37:16
 Re: Ford 309 Corn Planter.... in reply to dave404, 04-19-2014 05:15:22
ive got the bolts out of the 2 sides. 3 per side.
i removed both grease fittings.
it will have to be heated.
iif i can get the outside cast off, will auger come out
OH - 961
04-19-2014 18:30:42
dave404,
You don't want to get anything with acetone in it on fiberglass or any plastic parts. It will damage any plastic it contacts.
Myron
farmer jack
04-19-2014 06:11:49
I would heat some olive oil in a sauce pan and pour in there and let it soak. I have had good luck with oil oil eating through rust as I see the rust in suspension. also works when using a torch I immediately pour olive oil in the joint and they typically come apart.
maxwell99
04-19-2014 05:48:34
is there anyway you could pour or let it set in a 50/50 mixture of acetone and automatic trans fluid
that is suppose to be one of the best penetrating oils out there, might be worth try.
did you get corn plates with it, some said they are hard to find?
dave404
04-19-2014 06:07:17
 Re: Ford 309 Corn Planter.... in reply to maxwell99, 04-19-2014 05:48:34
yes. it came with a set of plates. I will try the AT fluid and acetone
jdemaris
04-19-2014 05:42:26
I've never seen PB Blaster work on anything that was truly rusted stuck. I've got two 309 planters. If I don't soak the fertilzer auger in oil before I put it in storage - it will be stuck the next spring. When I got mine - they were both stuck something awful. Took some careful torch work to get them apart. The plastic shutter on the bottom is a hard part to protect.
maxwell99
04-19-2014 05:55:24
 Re: Ford 309 Corn Planter.... in reply to jdemaris, 04-19-2014 05:42:26
third party image
same here,
on my little john deere planter, when I am through using it,
it gets a good wash job, then I pour used oil into all the planter boxes and fertilizer boxes and let it run out, then as I am taking it back to the storage shed, (under a big oak tree) I let the wheels roll, which works all the gears insuring oil is into all crooks and crevices.
so far, after many years this procedure has worked, its always ready to go each spring.
