Belt tracking Vermeer 605 G
david1
04-03-2014 05:16:12
Got this baler and have not baled with it yet. The belts all seem to track to the side right side. That's the side where the twine boxes are. The previous owner has been rotating the short pipe guides that are between the belts. Can anybody tell me if its going to effect baling or will they track straight with hay in it. Thanks
Hogleg
04-03-2014 05:30:51
 Re: Belt tracking Vermeer 605 G in reply to david1, 04-03-2014 05:16:12
Probably normal wear. See how it does with hay in it before you get too concerned. They will tend to hit those guides at times and they are a wear item. Once you get some hay in it, and you are rolling it fairly flat, observe if one or more are tracking correctly. If a lot of them are tracking towards one side, you can adjust he bars at the top to square it off. IF only one is tracking to the side, probably needs to be re-laced square.
Info in the owners manual. Have a pdf link if you need to print one out. It is for a Super G but almost the same.
John (605H owner)
