I"m currently rebuilding the knotters on my NH 68 square baler. The bronze rollers on the knife arms were worn out. I took a carbide bit and just cut enough of the metal off where it had been bradded over, to remove the roller. Is it ok to just take a welder and weld enough to the end to where the roller can"t slide off? Or should I put a small washer on and weld to it? Everybody said to get the bill hooks that had the brass roller for sisal twine. Messicks shows the steel roller bill hook only now. Will this cause any issues? Any other tips or suggestions on rebuilding these? Thanks for all your help.
