Case Centennial Trip Plow Won't Properly Lower
PK2013
05-10-2013 15:19:51
I recently bought a Case model Centennial pull type trip plow. The former owner tried to use it but stated when he tripped the plow, the plow acted like it wanted to go down but would immediately raise back up. I am not familiar with case plows so anything advice would be greatly appreciated.
PK2013
05-11-2013 07:40:52
 Re: Case Centennial Trip Plow Won't Properly Lower in reply to PK2013, 05-10-2013 15:19:51
Would there be a spring or anything inside the trip mechanism that might be broke or damaged? I plan to take the trip mechanism apart but wanted to get some feedback first. Also, what weight oil should I use in the trip mechanism? The type of plow I have is an oil bath trip mechanism (Case Centennial plow)?
rabbit
05-11-2013 07:04:39
May have to disassemble, clean out old grease, relube, and reassemble.
casecollectorsc
05-10-2013 18:21:21
You just give the trip rope a quick tug to trip it. If you hold the trip rope forward too long it will cycle back to the raised position.
