Erik Ks farmer
Had the wear strips replaced and the baler gone through the dealer shop last fall. I don't use it much, baled 200 bales a month ago and pulled it out to bale some for a landlord today. Wire boxes were empty, replaced wire and routed correctly (I checked 3 times), now when it trips to tie the needles don't return all the way to the home position but stay in the chamber and throw the saftey stop. Cleaned all the hay out of the baler and turned everything over by hand got it to tie and then started the baler and went into hay and promptly broke the shear pin and found the needles in the chamber agian. Thoughts please?
