Question for Roger in Ia or anyone else????
Tx Jim
04-29-2012 06:17:30
Roger
Yesterday my JD 467 rd baler kicked out 2 bales with no apparent Netwrap on the bales and gave no "error codes" on the monitor. I looking inside baler and found no net wrapped around rollers. I looked in operators manual under trouble shooting and found no solution. I'm suspecting knife out of adjustment or not sharp enough but don't know. Baler has around 13,000 bales but I forgot to check for correct number.
Thanks,Jim
Tx Jim
04-30-2012 09:28:41
 Re: Question for Roger in Ia or anyone else???? in reply to kermit vetter, 04-29-2012 06:17:30
Belt is good. It only does this once in a while but it is aggravating to have to re-bale a non-wrapped bale.
yellowdeere
04-30-2012 04:53:45
 Re: Question for Roger in Ia or anyone else???? in reply to Tx Jim, 04-29-2012 06:17:30
how good is your belt
Tx Jim
04-29-2012 16:17:00
 Re: Question for Roger in Ia or anyone else???? in reply to DeltaRed, 04-29-2012 06:17:30
JDseller
I checked parts keys #6 & #9 and they had no obstructions of material. On the possible low voltage I may have that corrected as I adjusted my loose alternator belts.
I also checked the roller to actuator clearance and it was .042 instead of .039 so I adjusted it. I will try again tomorrow.
Thanks for your help,Jim
This post was edited by Tx Jim at 16:21:08 04/29/12.
Tx Jim
04-29-2012 11:03:28
 Re: Question for Roger in Ia or anyone else???? in reply to evilboweviel, 04-29-2012 06:17:30
Thanks to all for the replies. Can intermittent low voltage possibly do this? I'm aware of Channel 15 for checking voltage.
JDseller
04-29-2012 11:18:27
 Re: Question for Roger in Ia or anyone else???? in reply to Tx Jim, 04-29-2012 11:03:28
It can but usually the monitor will act up if that is causing the problem. I just hook a volt/ohm meter to the monitor supply. Then active the surface wrap actuator. It should not drop below 10 volts when working.
JDseller
04-29-2012 10:07:51
third party image
Item #6 is what hits the micro switch and item #9 is the channel. The picture looks different than the ones on my balers. I just went and looked at them. I have two JD 567s.
They do that every now and then. Usually you will find the net wrap in a ball behind the knife. The sensor that tells you if there is net wrap on the bale is activated by a swinging "L" shaped piece of sheet steel. This is right in front of the knife, it goes completely across the baler. It activates a micro switch on the right side of the mesh wrap attachment. I have had issues with this getting hay behind it so it can't swing and also just rusted up at the the pivots. It just has a rod that slides into a flat bracket with a hole drilled in it. A cotter pin on each end holds it in. It is activated when the knife/brush pushes the wrap up toward the baler as it cuts it off. It has to move real easy or it will not work right. When it is stuck the monitor still thinks it has not finished the bale. The cycle is not complete so the warning system is in kind of limbo. It does not show a bale not wraped so part of it thinks it should be putting mesh wrap on. Another parts knows it has timed out so no more wrap is applied. You have to raise the gate to get the monitor to reset.
Roger in Iowa
04-29-2012 07:22:20
I don't believe it is a knife problem if there was no wrap anywhere.. Did you look way up to the top roller?
Been eleven years since I have been around a baler. Sounds like the net was not activated, otherwise there would have been net somewhere. Need to have someone watch the wrap mechanism as it wraps.
Others chime in here.
oj
04-29-2012 07:19:32
Not sure on a JD, but my Claas sometuimes does the same thing, it's problem is that the 'tie' mechanism is driven of the drive chains so it thinks it's tieing even if the wrap isn't being put on... the only thing i've found is that sometimes the spring loaded brake on the net wrap can be too tight... On a claas the brake sits on top of the net roll... i take it off until the roll is about half done...The other thuing that can cause problems sometimes is rust where the net wrap roll sits, i wire brush mine clean at the start of the season, then the wrap keeps it clean the rest of the year...
