Plow Difference
bigr
03-25-2012 10:25:06
I bought a IH Disc Plow off of here cause it's something you don't see everyday. I have been told a Disc Plow is for sandy ground where a moldboard plow wouldn't work good. Just wondering where the difference is and why you would use one?
DiyDave
03-26-2012 03:58:31
 Re: Plow Difference in reply to bigr, 03-25-2012 10:25:06
In addition, to what others have said, disc-plows cut roots, up to 3". If it's over that size, it rolls over.
Brendon-KS
03-25-2012 19:21:18
Some of my old farm equipment books state that a disk plow will penetrate hard dry clay soils where a moldboard would have problems.
Maxwell99
03-25-2012 18:57:53
third party image
I have a ferguson disc plow.
if you have a lot of loose material that can clog a flat bottom plow,
an old disc plow with cut right through it and just keep going. They also pull eaiser than a flat bottom plow,
but if the ground has a lot of heavy turf the disc plow will leave the ground rough.
however, that is good for fall breaking as it puts the dirt up in the air to dry and then it falls apart in the spring.
picture of my old fergy disc plow
Dave Sherburne NY
03-25-2012 11:21:10
I think the disc plow is used on land with rocks and tough roots not necessary in sandy ground. It rolls over obstacles. The moldboard plow would work a lot better in the sandy ground.
DeltaRed
03-25-2012 11:16:11
Rocks.A disk plow will roll/bounce over big rocks.A moldboard plow will 'hook' the rocks and bend the $#!+ out of things-just tear it all to he!!.
