Ford 860 Implements
Tom Bond
Hi. Looking at possibly bidding on an 860 next weekend at auction. Going to use it for working the ground for food plots, bushhogging, etc. on a 60 acre parcel used for 50% hunting and 50% tillable.
Does anyone know how available discs, mowers and plows are for something like this and does it have enough power to use for these kind of jobs? Thanks in advance!
Guess you have little knowledge of tractors if you ask this. The 3 point system came out many decades ago and all companies have since gone to it so it is easy to find plows disk etc etc etc for a tractor like that
Nice tractor.
Most 3pt implements designed for tractors of 20 to 40 hp will work, so you have about the most popular size of old tractor to get things done.
--->Paul
I have two 860 ford tractors and in our Missouri ground it will pull a two bottom plow, run 5 FT brushog, run about any small square baler, back scoop, and much more.
