JD 290 part needed
SB in IA
02-21-2012 07:08:33
I am searching for a shaft bearing part# H1736B. It is on the far right of the drill shaft. Also looking for the drawbar ball and arm part# H2516B. The ball and arm isnt greatly needed as mine just has the broken arm the marker chain hooks to. Ball and hitch is still functional and i just will have to manually raise and lower marker arms, no big deal, not planting a ton and i need the exercise but i do need the shaft bearing for the planter to plant. Let me know what you got and we'll go from there.
Thanks!
Art Massing
02-22-2012 17:55:24
 Re: JD 290 part needed in reply to SB in IA, 02-21-2012 07:08:33
SB,
Deere's parts page indecates that those part # are no longer available but you can have your local dealer run a part search on their obsolete parts network. Hold on to your hat when they give you the price.
I"ve had the local machine shop refit that type of bearing with bronze bushings. May be a lot cheaper (and better) than new.
Good luck with it,
Art
Case Nutty 1660
02-21-2012 09:13:20
guy on the tractor forum has some extra parts from a parts machine might check with him cnt
SB in IA
02-21-2012 07:12:13
To clarify: if you are standing behind the planter looking towards the front the bearing is on the right side of the drill shaft.
