white 5100 planter boxes
Vernon in Ks
01-18-2012 05:45:39
I asked this question before but didn"t get a response so I"ll try one more time. Will the seed boxes from a White 6100 fit the planter units on a 5100? I would like the bigger boxes but don"t know if the mounting base is the same. Anyone done this?
Gary Koenigstein
01-22-2012 15:27:05
 Re: white 5100 planter boxes in reply to Vernon in Ks, 01-18-2012 05:45:39
The clips that hold on the boxes on the meter base are much heavier on the 6000 as compared to the 5000. I have both models in the shed, not sure without looking but that might prevent a simple switch.
ihman73
01-20-2012 08:52:55
I didn't mind the screw on lids myself, better than the early deere/kinze lids that would blow off going down the road when they got broke in.
ihman73
01-19-2012 19:04:38
Looked at both planters today, without pulling the boxes to get a tape on them they look identical. But the capacity is practically the same on both boxes.
Vernon in Ks
01-20-2012 05:16:11
 Re: white 5100 planter boxes in reply to ihman73, 01-19-2012 19:04:38
I think there is a half bushel difference. and the lids should be different. the 5100 has screw on lids and the 6000 has sliding lids.
Bob Bancroft
01-20-2012 05:45:06
 Re: white 5100 planter boxes in reply to Vernon in Ks, 01-20-2012 05:16:11
Just getting away from those screw on lids would be worth the change. I hated them!
ihman73
01-18-2012 18:21:58
As far as I know they are the same size meter base. I have a 6 row 5100 and a 6342 12/13 splitter I will check it out tomorrow when I get to the shed.
Bob Bancroft
01-18-2012 16:24:51
Apparently no one on here. When I researched putting the larger seed plate drive hubs from a 6100 (and newer) on my 5100 it certainly appeared that the base mount was the same size, but that's just a guess.
Vernon in Ks
01-19-2012 07:30:18
 Re: white 5100 planter boxes in reply to Bob Bancroft, 01-18-2012 16:24:51
Thanks guys. I need to replace 5 of the 6 boxes and would like to go with the bigger box.
