IH 311 plow
Strikefalcon
10-16-2011 22:27:42
Couple of questions.What does it weight. What's it worth in unrestored but all there condition. Would it be to much for a IH350D utility to pull. I'm in Mn if that matters.
Thanks
robgIN
10-18-2011 09:32:25
 Re: IH 311 plow in reply to Strikefalcon, 10-16-2011 22:27:42
it should pull it, but the utility version does not have a really strong differential. We used to plow with a 350 utility and similar plow and over the years had to replace the diff twice. If you are only going to do a few acres I wouldn't worry about that.
formerly ny bill
10-17-2011 17:49:03
dad had a 311, usually pulled with a farmall 300, but occasionally with the 300 utility. the utility has enough power but was some short on traction. 300 and 350 should be similar in hp. as to value, lots of variables. coulters or not? i have 2 311s. neither has coulters. one with rigid beams cost me $125. the one with trips was a gift, but worth more than the rigid one. also, you need to check the frogs. plows that age may have been worn/abused to the point that the front bolt hole on the frog is all or part gone. makes it a lot harder to keep the share tight.
weight? i don't know but it didn't overload the 3/4 ton pickup. maybe 7-900#? hth
strikefalcon
10-18-2011 06:24:34
 Re: IH 311 plow in reply to formerly ny bill, 10-17-2011 17:49:03
thanks, there is one for $850 for sale locally. It is the non-trip version. sounds way high.
formerly ny bill
10-18-2011 18:05:52
 Re: IH 311 plow in reply to strikefalcon, 10-18-2011 06:24:34
i would think you could find one for lees than half that. trips are good if there are any deadmen if the ground you plow.
