I just bought a 909 rotary mower, and the PTO shaft is too long. I've read
where you should cut equal lengths off both implement and PTO shafts, but the PTO shaft seems to be the one designed to be cut. It has the rectangular section running the entire length while the implement shaft only has a short rectangular receiver.
I need to hack at least 6 inches off, so is there any reason I can't shorten only the PTO shaft? Is there a problem with it being too short? Any other advice appreciated.
Thanks,
JK.
Thanks,
JK.
