LA cultivators
Plowboy3010
07-10-2011 13:21:50
I have a John Deere LA and I recently bought some cultivators to go with it. I am missing the L shaped brackets that bolt onto the front of the tractor. I would like to get some measurements and dimensions on them so I can make my own. I am also wondering if there is anything else up front that the cultivators mount to that I might be missing.
WAYNE-N-TX
07-11-2011 06:49:52
 Re: LA cultivators in reply to Plowboy3010, 07-10-2011 13:21:50
I have a JD LA and have a good many implements for it, it's a 1944 and it don't have the part you're talking about. The larger tractors has that, the only thing I can think of, maybe you have the implement for a different tractor.
plowboy3010
07-11-2011 16:21:28
 Re: LA cultivators in reply to WAYNE-N-TX, 07-11-2011 06:49:52
I have a pdf manual for it and the bracket mounts to the round tubing just below where the belt pully would bolt on and the same place on the opposite side. Its not quite an L shape but not far off.It has 4 small round holes 1 large round hole and 1 square hole. My manual says the part numbers are 23810A and 23811A
