hay sticking in end on NH469
Jimmy in Indian
07-07-2011 07:02:44
I have hay sticking in end of cutting bar away from tractor. I did notice the rock guard part of it was broken on top. That could be part of it but in a previous forum someone mentioned a bar on outside that may have been broken off. Mine does not have this. Tell me more about this bar or I am open to other suggestions. I had no problems in 2nd cutting alfalfa but moved to thick 1st cutting grass and fought it all the way through.
david1
07-08-2011 13:58:56
 Re: hay sticking in end on NH469 in reply to Jimmy in Indiana, 07-07-2011 07:02:44
My 488 is having the same problem in heavy hay. There is a thing called a wear plate that mine was missing out on the end of the sheet meatl. It is about 6 in long and is a channel that covers the point ot the last gaurd. Also the plastic piece needs to be out there also. I am also replacing the tine teeth on that end of the bar that pulls the hay in. I have not had a chance to go and try it out yet as we are having rain every few days.
Jimmy in Indiana
07-11-2011 08:52:01
 Re: hay sticking in end on NH469 in reply to david1, 07-08-2011 13:58:56
Where does the plastic piece go?
Jimmy in Indiana
07-07-2011 09:34:25
I have that special 2 point cutter. There is a homemade rubber guard over the end to keep hay from being dragged in. I am way behind this year and wanted to at least get finished with this field so I fought it. I will look closely at the guards and cutters this weekend and replace if needed. I just wondered if there is anything else I was overlooking.
Allan In NE
07-07-2011 07:33:39
Yep,
Where-ever the hay is "sticking", there is something wrong with the cutter bar, sickle, guards, etc. in that area.
Allan
showcrop
07-07-2011 07:21:47
Do you have the special end section on it? There should be one with two points instead of one.
KEH
07-07-2011 13:21:59
 Re: hay sticking in end on NH469 in reply to showcrop, 07-07-2011 07:21:47
Sounds like you need a new guard on the end. I would put a new one next to it also.
KEH
