ih 900 planter
jim ih
04-18-2011 15:57:30
got a flat tire on 900 row planter. what is easiest way to take off. any ideas. jim
cjmal
04-20-2011 15:34:54
 Re: ih 900 planter in reply to jim ih, 04-18-2011 15:57:30
thanks 560 it worked out .found bad bearing when pulled shaft out. thanks jim
560farm
04-20-2011 03:30:34
If all carrying wheels are on ground with planter in raised position dig a hole, remove pin from lift cylinder assembly, let assembly swing down in hole, remove 3/8 bolts, shims and 5/8 bolts on each side of hub and drive/push/pull hex shaft out. Then roll tire with hub still mounted to rim out from under. If it's mounted or end transport type and raised in the transport position, remove pin from lift cylinder, let assembly swing down, remove 3/8 bolts, shims and 5/8 bolts on each side of hub and drive/push/pull hex shaft out. More than likely you'll have to drive the hex shaft out, be sure to clean it up and put antisieze on it before reinstalling. Hopefully this makes sense.
flying belgian
04-18-2011 19:45:48
On the 400 you just take the nut off either side of the axel and slide it out.
