old AC hay rake
timber beast
04-10-2011 06:14:30
I have an older AC side delivery hay rake, model unknown. Belt is not on it. I need to know how to route the belt, can't figure it out. Thanks.
timber beast
04-10-2011 14:39:33
 Re: old AC hay rake in reply to timber beast, 04-10-2011 06:14:30
Thanks for the replies. Any other help will be greatly appreciated. I'll try these tips and see if I can't get this thing going.
Tim(nj)
04-10-2011 12:20:29
I did one once, and I'm working from memory. Put the belt around the big pulley on the axle. Follow the belt over the top of that pulley. It will go around the idler that's farthest from the tractor, then goes under the pulley on the basket wheel. Then it goes over the front idler and back to the bottom of the axle pulley
Ken Sweet
04-10-2011 11:27:02
I put one on about 15 yrs ago and I can remember keeping the V part of the belt in the pully grooves and the backside of the belt ran on the idlers. I know that is not much help. Best I can do. Ken Sweet
DeltaRed
04-10-2011 10:28:22
The only AC hay rakes i've seen have only used a #50 chaindrive-pto driven
Skyhighballoon(MO)
04-10-2011 12:21:27
 Re: old AC hay rake in reply to DeltaRed, 04-10-2011 10:28:22
Latter 77G and 78 model hay rakes were belt driven.
Mike
