Howdy. As some may have seen over on the AC boards, I've got a little D14 with a snap coupler 2 bottom plow. I've been working on getting it to dig in a little better, and I thought I finally had it today. I adjusted both cranks on the plow and set the coulters a little deeper. It did pretty well except my larger moldboard that's the close up of the furrow just doesn't get dug in and throw sod. It isn't the ground. It's soft down eight inches and more, but the plow has been slowly getting worse about getting dug down like it should. The first moldboard still digs in pretty decent, but the second one is down to skidding along on top of the sod. :?: :? Any ideas what I need to do? My coulters are sharp and cutting the sod perfect. I just need to work on getting this thing adjusted because we're planting some spring grains in early April.
Thanks,
MYT
Thanks,
MYT
