waterman74
Can anyone tell me if an 8n will run a John Deere 214t square hay baler?
(quoted from post at 04:09:13 12/12/10) I would try it. What do you have to lose. Without the live pto when you hit a slug or hard spot quickly step on the clutch, pop it into neutral and let the clutch out again to get through that. It will come natural after awhile and you won't miss a beat. I would enjoy the challange. Of course I grew up doing that kind of stuff with those smaller tractors.
(quoted from post at 05:11:04 12/12/10) Your 8N does not have any remote hydraulic on it. You would not be able to lift the haybine up for turns. Plus your gearing is way off. The big problem is horsepower. A NH 479 in good hay can take 50-60 horsepower. I have a nieghbor that uses a WD45 on a JD 1209 and he has his hands full in four foot timothy hay.
I would look for a three point drum mower. Your tractor would pick it up easily and they cut well.
(quoted from post at 05:14:09 12/12/10)(quoted from post at 05:11:04 12/12/10) Your 8N does not have any remote hydraulic on it. You would not be able to lift the haybine up for turns. Plus your gearing is way off. The big problem is horsepower. A NH 479 in good hay can take 50-60 horsepower. I have a nieghbor that uses a WD45 on a JD 1209 and he has his hands full in four foot timothy hay.
ok, thanks for the reply, so the haybine is out...anymore opinions on the baler JD 214T
(quoted from post at 17:33:16 12/12/10)
waterman74
A sq hay baler isn't easy to load on any size trailer. I'd take a spare 6 hole impl wheel wt tire and repack wheels brgs and tow it home.
(quoted from post at 22:40:14 12/11/10)
oh, any idea if that baler will fit on a 16x6.5 trailer?
(quoted from post at 17:03:19 12/12/10)
I did notice he had the PTO started before he actually started moving...not sure how he did that unless he had the famed Sherman live PTO and his windrows were pretty small.
(quoted from post at 10:14:33 12/16/10)
A good baler is harder to find than a bigger tractor.<<snip>>John
