I recently acquired a Char Lynn PTO pump/reservoir unit. The pump is enclosed inside an aluminum reservoir. There are two splined control shafts at the end of the reservoir near the PTO connection. The pump/pumps inside look to be a single-action and a double-action pump side-by-side with connections. I would like (need) to know the intended purpose of the connections and controls.
If anyone has a manual or illustration for this unit, or even experience with such a pump, I would like to get in touch with you. Through this site I have learned what exactly I have in my hands, now I need to learn how to use it or adapt it for crankshaft connection, if possible. I think the unit is called a Hy-Lo power pac. There are no numbers anywhere on the unit. I get no response from Eaton who took over Char Lynn years ago. This is probably too old for them to have manuals, parts, or to even care! I will continue to check this tjread, or my email is digiterry at netscape dot net. Make the obvious and appropriate changes in symbols.
Thanks much, Terry in Iowa
