Anonymous-0
I've got a weird issue with my 336, which is making perfect bales by the way. It runs great in a straight line. I'm running it a little under 540 rpm PTO, probably closed to 400 or so. When I'm turning when it's not picking up anything the makes a terrible racket like something is coming apart and as I straighten out it sounds great. It seems to especially dislike turning to the right, left doesn't seem quite as bad. I'm not turning tight at all, the u-joints havn't even begun to start knocking. Is this a plungerhead adjustment issue? Maybe it's too lose in the chamber and the back and forth motion while turning is causing it to bang side to side? It's bad enough to where I just pull the rpm's back to idle as I'm making a turn and turn as gradually as possible. Maybe this is just typical of square baling as I'm just starting out and there may be a technique I need to learn.
Thanks!
Thanks!
