JD plow
wijim
09-23-2010 14:05:05
third party image
I have a three bottom mounted with trip bottoms was wondering what number it is. I think it might be an 810 it has gauge wheel. Il see if I can find a pic. Thanks,Jim
Carlyle Hoffman
09-23-2010 15:41:28
 Re: JD plow in reply to wijim, 09-23-2010 14:05:05
Best way to tell, is if tail WHEEL goes in to the CASTING that is attached to the last BEAM , mounts left to right it is a #810, if it goes in from the FURROW side then generally it is a #813 The tail wheel axel mounting bracket that bolts to the frame with 2 bolts is the determaning factor. Add a photo of the tail wheel assembly????? ????? ??? Normally #810s had a STEEL tail WHEEL and #812-813-and 814s had a RUBBER tail WHEEL ASSEY.
Carlyle Hoffman
09-24-2010 13:54:16
 Re: JD plow in reply to Carlyle Hoffman, 09-23-2010 15:41:28
Hey , you got an #810. The tail WHEEL MOUNT CASTING , the ROUND BRACE instead of the FLAT BRACE the STEEL tail WHEEL all were only used on the 10 SERIES. 12-13-14 series used FLAT BRACE, RUBBER TAIL WHEEL and only 1 sided WHEEL AXEL CASTINGat FRAME.
wijim
09-24-2010 07:46:32
third party image
third party image
pic of tail wheel. Thanks,Jim
wijim
09-23-2010 16:40:25
This one has a steel tail wheel. Thanks,Jim
