Auger drive 14T
Bret4207
08-25-2010 14:05:27
On the outboard end of the auger drive on my 14T baler there's a shear pin (I think) that's held by a set screw. At least I think it's a shear pin, there's a hole there. Anyone able to tell me what goes there? And no, I don't have a manual, yet.
ET
08-26-2010 18:34:50
 Re: Auger drive 14T in reply to Bret4207, 08-25-2010 14:05:27
A hardend bushing is held in by the set screw and the shear pin drives through the bushing.
Bret4207
08-26-2010 05:26:28
Thanks guys, I figured it was shear pin of some sort. This baler was a freebie. I'm not sure if I'm going to keep it or sell it. Has the Wisconsin on it.
Bob
08-25-2010 18:59:28
This is the pin, I think, Key #25. Not a REAL expensive part. (Key #32 is a heavier pin used if there is a slipclutch installed on the upper (drive) sprocket.)
Part Details
Part Number: 25H729 Part Price: 0.46 USD
Description: PIN, GROOVED
Third Party Image
tim[in]
08-25-2010 15:54:49
A very sensitive shear pin. But i learned to save my small broken pieces and use them again till there was too little to use. They a frequent breaker when the humidty increases or dew falls. I used to be able to set my watch by when it started breaking. 7:00 pm! lol That is the reason i am thinking of getting a 24 T for th enext baler, but in farm show one guy replaced his belt drive on 24 T with the same setup as on the 14 T . Go figure. i can deal with the belt slippage as opposed to constantly replacing those poins.
jiminct
08-25-2010 15:27:45
i had a 14t and have a 24t now, w/ out looking at the manual i'm not sure how it all goes together there but i believe in that hole you're talking about is the shear pin that holds the auger in place. on ours it was bolted on instead of the shear pin. which would work as long as you're careful and don't try to bale any large sticks/logs, or other big junk. def. get your hands on a manual though its a life saver esp if you have no experience working on a baler.
old
08-25-2010 15:13:28
Yep that is in fact a shear pin sort of thing. Been years since I have looked at the 14T I have and sorry I'll not go wade through the weeds to look at it but you should be able to get that shear pin from JD
