Ohiohillbilly
The Haybine from Hell is gone for now. I put the finishing touches on it today. Then I hooked it up to the 400 and knocked down a few hundred feet of grass in the field. Went and parked it and called the neighbor. I told him it was done but wouldn't be able to drop it off till tomorrow. He sent one of his boys over to get it so it was gone when I got back. He said I can use it whenever I want, just have to decide if I want to!! I cut out the whole bottom plate. It was hardly 1/8 inch and I replaced it with a solid 1/4 plate. I plug welded an angle to the bottom to stiffen it up some. I did extensive re fabrication of the hitch tube because the top pin bushing was destroyed. All in all it was a real PITA but it is done.
From this
To this
To this
From this
To this
To this
