I have a Cockshutt 311 Side Delivery Hay Rake.
The part I'm researching is R-5107 which is the "SPRING - Chain Tightener Arm".
On this particular hay rake, it's a chain drive which requires a chain tighenter which is just a metal arm with a block of wood attached at the end. The block of wood actually rubs against the chain, and the SPRING keeps the block of wood push against the chain.
I'm looking for the SPRING or at least what the RIGHT SIZE and TYPE of spring I need. Again, the part number for the Owners Manual is R-5107.
