Assuming one has relatively flat hay fields: How often do have to adjust the hydraulic lift cylinder when cutting hayfields with a Haybine or Moco? Is lifting required for road transport only?
Where I am going with this is would it be possible to use an older tractor that has the horsepower (Case DC with MW's or Firecrater's) but no hydraulics to run a Haybine or Moco? I would be using a hand crank ratchet cylinder in place of the usual hydraulic cylinder. (My field is relatively flat. I do have an incline in one area but it is a flat incline).
