atk_nut
Does anybody have an exploded view of the bearing area handy?
I noticed that there was a "drool" of oily stuff coming out between the "barrel" and the hub today.
Is there oil in there? It looks to me that it's grease only, but I could be wrong.
Thanks.
Check the PZ download document archive
http://www.vicon.eu
or
http://www.kvgportal.com/interparts-kvdoc/input.jsp
All haybob files are in PDF to download.
8) Bauke
(quoted from post at 03:54:16 06/07/10) Does anybody have an exploded view of the bearing area handy?
Thanks.
As far as I know those things just use sealed bearings and open bevel gears in the gear head. If there's grease running out then somebody probably used a lighter grease than they ought to have used.
If you can't rock the rotors on the gear head I wouldn't give it a second thought.
Haybobs were pretty tought. Small/slow to work with, but tough.
Rod
