Have a single 16 Oliver w/ rooster comb lift. Plows great, but getting it out of the ground by tripping it is the problem. I trip the plow while in the ground and the rooster drops and cannot complete the full cycle (ride up rollers 1/2 way then the rooster hops out, cycle repeats 1/2 way then rooster hops out, on and on).Looking for ideas on what to look at next. Replaced lift spring on rod w/ new spring. Replaced 1 1/2 turn spring under lift pawl. Made sure rooter and rollers are aligned. Eveything moves freely and is greased. Adjusted hitch on tractor high and low. Played w/ levelling lever, no change. While in ground, stopped, pulled rooster all the way up, no change. With 1 person having 1 foot on rooster comb (keeping it in thee rollers), plow will pick itself up). Help, want to use this on 4/17, but I can not trust it.
