Bill n Cntrl WI
New User
Just purchased a 1968 Ford 2000, 3 cyl gas, 2wd. Runs very well. Rear tires are not loaded with anything at this time. Still trying to decide on fluid or weights. "Everything Attachments" has a disc harrow that I've been thinking about getting. Its cut width is 6'10", it has 20 18" discs, and weighs 700 lbs. The ground type is silt/sandy loam.
Do you guys believe this tractor will be able to effectively pull this disc harrow or should I play it safe and go with a lighter/smaller disc?
Thank you for any input. Bill
