Disc Mower Curtain...??????
KRS_MED
Does anyone know of a online source for a aftermarket disk mower
curtain? Didn't really come up with much when I googled them.
Keith
You might consider conveyor belting. I needed to replace a NH discbine skirt and the neighbor had a roll. He sold me a 6' section for $5. Can't beat that...
You need to be carefull with coveyor belt. If it's too heavy or stiff it will push the hay over and the mower won't cut. I'd think that probably 1/4" thick or mabey a 2 ply type belt would be as much as you would want. I used some 1/2" belting and bad to cut it off. Just too heavy.
Rod
we used a piece of carpet on our Gehl about 3 years ago, and its still on there. Just have to trim the strings off before you go to the field. Not a "factory replacement" but it was cheap and it works.
