JD 336 vs 337 baler
jeffdeere
12-20-2009 18:45:47
What are the differents between the two balers.
Tx Jim
12-22-2009 04:16:57
 Re: JD 336 vs 337 baler in reply to BDT in Minnesota, 12-20-2009 18:45:47
ET said: (quoted from post at 09:21:26 12/21/09) The 337 is the old 346 baler. The 336 became the new 327 baler and the 347 was the only real new baler in the line.
That's not the way I remember
336 replaced by 337 both twine or wire with 3 hay dogs but 337 had wider pu
346 replaced by 347 both twine or wire with 6 hay dogs but 347 higher cap
327 came in twine only with narrower pu than 337
ET
12-21-2009 05:21:26
 Re: JD 336 vs 337 baler in reply to jeffdeere, 12-20-2009 18:45:47
Tx Jim
12-21-2009 03:44:34
 Re: JD 336 vs 337 baler in reply to Joe Watkins, 12-20-2009 18:45:47
jeffdeere said: (quoted from post at 22:45:47 12/20/09) What are the differents between the two balers.
337 is newer model
jd-tom
12-20-2009 21:06:39
The 337 has a wider pickup than the 336. There are also some improvements on the knotter.
Ken Macfarlane
12-21-2009 18:13:53
 Re: JD 336 vs 337 baler in reply to jd-tom, 12-20-2009 21:06:39
The knotter changes I think are the twine disc is easier to adjust (no clue how to on my 336) and possibly the twine knives bolted instead of rivits.
