Can anyone i.d. this hay rake?
plussier
New User
I'm trying to replace broken teeth on the rake but can't find a make or model badge anywhere on the thing.
The tooth is one of a set of replacements that I've now used up but have worked fine. I'd like to get more.
I'm not positive, but I'm guessing by the little picture you posted it looks like a Massey Ferguson to me. I had a Massey Ferguson pull type rake some years back that looked very similar to your picture. Hope this helps. Good luck.
Kow Farmer
Thanks for the help. If you are in the modern view you can click on the photos, they're live links to a bigger view.
Looks like my neighbours old MF too but I don't know the model. Tine looks like a standard New Holland one, same as on the 256 etc.
Unsure of the make on your rake. However, I bought a rake last year that turned out to be a Minneapolis Moline. I couldn't find any teeth for it and simply measured the teeth I had on it. Length, diameter of tooth, diameter of circled spring (the tooth looks almost exactly like the one you picture) and then length above and below spring section or tooth. I went in search of a tooth that matched these measurements and found they were pretty common.
Mystery solved. The local MF dealer discovered the identity of the rake. It's an IH #9. He also tracked down a source for the tines. Thanks all for your input.
