14T Baby Bales Problem
Jonaspear
New User
This is my second season using a 14T for small squares. I make about 750 bales a year, 200 or so at a time. Last year I had a few (1 or 2 per 200 normal) mini-bales mixed in each time I baled. The last time that I cut this year they seemed to be more frequent, maybe every 10-15 bales. I always assumed that I was just hitting chuck holes and tripping the knotters but I know that wasn't the case this time. The little things are cute (toddler sized) but I'd just as soon not waste the twine.
Any suggestions? Thanks
it's been a while but i thing the needle brake needs tightening. others can/will verify. excuse no caps, hand in cast.
Jonaspear
Too much air in LH tire or hitting a hole at same time it trips to tie. Also the measuring arm can just drop and then pop back up a little. Later JD balers had a spring to help hold measuring arm down.
