wheel for a JD model H spreader
KARL B
07-11-2009 13:31:47
Does any one know where I can get a 22" spoke wheel for a John Deere model H manure spreader? The wheel takes a 7.50-22 tire. The tires are also hard to find. I have heard that they are not manufactured any longer.
Jim in Michigan
07-15-2009 12:23:46
 Re: wheel for a JD model H spreader in reply to KARL B, 07-11-2009 13:31:47
where are you located? I have a H spreader that I would sell, has a broken bearing holder on the back. Tires hold air and good wheels,,not sure on the size though,,Thanks,,Jim
KARL B
07-15-2009 16:34:16
 Re: wheel for a JD model H spreader in reply to Jim in Michigan, 07-15-2009 12:23:46
Jim;
My spreader is in very good shape except for the one wheel that is rusted beyond repair. That is why I am in the need of a wheel.
If yours has 22" wheels then I will take it.
I am located here in the Seattle Washington area. If you have what I need I will either have to go to Michigan or have it shipped. Please get back to me with the wheel and tire size.
Thanks, KARL
KARL B
07-15-2009 08:12:37
Thanks for your for your interest.
Shetland Sheepdog
07-15-2009 05:25:33
 Re: wheel for a JD model H spreader in reply to Sid, 07-11-2009 13:31:47
Nope, all 20's that's why I was wonderin! Just as a matter of interest, I've got an "L" on 20 inch wheels BUT 1 wheel is a drop center rim and the other is a "split rim" with the removable ring! If I remember correctly, they used to offer the option of using old truck tires and thats probably why they made the split rims available!? I do have an "H" out in the woods with a pair of 20 inch wheels, but they may be rusted beyond salvage, not sure!
Shetland Sheepdog
07-12-2009 04:31:49
 Re: wheel for a JD model H spreader in reply to ET, 07-11-2009 13:31:47
This may be a dumb question, and if it is I apologize! Are you SURE it's not a 20 inch wheel? I believe that most H's had 20 inch wheels! More dumb questions; did you measure the wheel? Where did you measure on the wheel? Were you able to read the numbers on the tire? HTH
Dave
KARL B
07-14-2009 20:39:38
 Re: wheel for a JD model H spreader in reply to Shetland Sheepdog, 07-12-2009 04:31:49
Dave, to answer your questions. Not only did I take the information off of the tire. But I also measured the wheel where the bead of the tire fits on the wheel.
John Deere manufactured both 20" and 22" wheels.
I believe that the 22" wheels were used in the early 40"s.
My question to you is, Have you seen any John Deere spreader model H 22"spoke wheels in your area of the country?
