LJS30
Gentlemen, where online could I find this part? Do any of you guys happen to have this part? What is it called? Thank you.
Inner part is called a spool, or bearing spool outer parts are called bearing halves. Agrisupply.com should have both parts, you will need to know the axle size and shape, ie: 7/8" square, etc. The 1 " square Part # is 28210, for the spool, and 28211 for the bearing half.
pokey here
Leroy- looks like I forgot to mention that, but if its too short of a bearing, it can be shimmed. I doubt it'll be too long, cause who has seen a chinese mfr that puts more metal into a part?
I did some measurements and I believe it's this one.
http://www.agrisupply.com/-bearing-spacer-spool-/p/11738/ss/Bearing%20Spacer%20Spool/
The length of the spool determines if it is a 6", 6 1/2", 7", 7 1/2" or 9" blade spacing on the disk and they could not be shortened or lengthend.
Leroy, I have lengthened them, generally before selling the disc, if it wasn't a keeper, just by adding some really big belvue washers, that I happen to keep on hand for just such emergencies. Of course if he is ordering a new part, he should get the right part, the point I was making is that most of the discs that I see are 7 inch spacing, imports sold by the box type farm stores.
