JD LA Snowplow
CT_Farmall
05-26-2009 19:10:23
Was lucky enough to purchase an original JD LA snow plow. Picked it up this weekend but need some pictures as to how to hook it up. Anyone have any digitals of how to hook up the lifting strap to the front pivot. The installation instructions describe mounting the lifting strap but don't show it. The bolt and sleeve in the lifting strap are perpendicular to the centerline of the tractor. There are no holes through the pivot shaft and the bolts that hold the bearing caps on the pivot shaft run parallel to the shaft. What am I missing?
Thanks CT
