mattofvinings
All, need advice here on the proper implement for my tractor (IH 460 utility if it matters).
I need to build a driveway/road of about 200ft where there currently is none and so I need to cut thru & remove the sod and a few inches of the topsoil to where the dirt gets a little firmer (confirmed by hand digging some holes). Then I'll bring in and spread out crushed limestone for a base.
All my reading about box blades has to do with levelling/filling high and low spots on an existing drive...I still think this is the right tool for the job to start from nothing but there's no sense going out to buy one when I need something else.
The drive will start as gravel and eventually be asphalt paved at some time down the road.
Thanks in advance for your advice.
