Ford 515 sickle bar mower
Billt102
New User
Have a chance to pick one up dirt cheap, (under $200). Will this work on my 2N? haven't seen it yet but it issupposed to be in working condition.
I still use my 515 for cutting hay. Should work on 2N if you have a drawbar that can be moved to the right and a working 3-pt. If you buy it make sure it has the bracket that has a link to attach the big release spring to the lower right 3-pt arm. Also make sure you get the chain with the smaller spring at end that attaches to the hole in drawbar. I'd also make sure main bearing is OK & lubed by removing rounded cover plate and take a look (not at home now but I think they're 9/16 or 5/8 bolts). You can still get an operators manual from New Holland. A good mower. I can post pics later if needed. Good Luck
