Disc Harrow Rear Blade
Bobby Addington
03-29-2009 10:24:49
Two part question.Need to know what was the color of old Bush Hog Brand rear blade-one with 2 large handles also I have a Imco Disc Harrow (tandem)-are all Disc's supposed to rotate (individually) by hand?Thanks for your help.Bobby
Mike Aylward
03-30-2009 06:22:38
 Re: Disc Harrow Rear Blade in reply to Bobby Addington, 03-29-2009 10:24:49
Bobby, in addition to the information the other posters gave, one way to tell for sure if your blades are tight to the gang is if they ring when you strike them. If they "thunk" they are not tight. They will turn as a unit and ring when they are struck if everything is right. Hope this helps. Mike
Bobby Addington
03-30-2009 17:58:56
 Re: Disc Harrow Rear Blade in reply to Mike Aylward, 03-30-2009 06:22:38
Thanks Mike for the added information.All this I'm sure will help me.Trying to get implements ready for paint and then ship them on up to the farm.Been working on 4 used implements-Older Bush Hog Brand Rear Blade-Homemade penetrating oil and tapping with a hammer got er going good-single row Covington cultivator- 2 bottom Dearborn Disc Plow-and Imco Tandem Disc Harrow-all for 3oo$.Not to bad I think.Thinking about painting them all red.Wish I knew tho Bush Hog paint color and Covington also.Disc Harrow and Disc plow will be red.
DiyDave
03-29-2009 15:43:33
If its real loose, Shoup sells a big washer, that is shaped like a disc blade, applies spring pressure to suck the axle tight to the last disc. If your spacers are wore out, you may have to weld them up, and grind them down in the right shape, to get the gang tight.
Bobby Addington
03-29-2009 15:58:36
 Re: Disc Harrow Rear Blade in reply to DiyDave, 03-29-2009 15:43:33
Thanks for the help.I know if I have to weld them up I can.Let me ask a question-Does the (gang) supposed to turn as a unit when you grasp and rotate one disc?
rankrank1
03-29-2009 15:16:05
Hopefully, you will be able to simply tighten the nut on the end of your shaft. However, a problem that we used to have with our old disks is that you can sometimes not tighten nut on the end of the axle due to being out of threads on the end of the axle. This is due to a combination of: the axle stretching a little bit, blades thinning some due continued use with them spinning on shaft, and the spacer hubs thinning some again to running while loose.
To fix this, you may need to washer the end of your shaft to get enough threads to tighten. Sometimes a traditional big flat washer will not work either. For anywhere that you might need a contoured shaped shim washer or a square hole type washer, then we would simply cut washers shims from our old broken disk blades that we kept around in our scrap pile - these usually worked best. We could usually get a well worn disk usable again with this method and the price was right - free.
This post was edited by rankrank1 at 15:20:41 03/29/09.
Bobby Addington
03-29-2009 15:34:54
 Re: Disc Harrow Rear Blade in reply to rankrank1, 03-29-2009 15:16:05
Thank you for this helpful info.I'm sure I'll be able to use it.
Bobby Addington
03-29-2009 13:25:10
We thank you sir.
JMS/.MN
03-29-2009 13:06:52
They should not rotate individually- the nut on the shaft needs to be tightened. Make sure the blades are clean, if dirty, they will work loose again when the soil particles crumble into dust.
