NoBite
I am not mechanically inclined. Better start by admitting that. I own a Ford 1900 tractor with a DuAl 105 loader. The loader is leaking hydraulic fluid badly from the ram on the right side. I want to remove that ram and take it to the local implement dealer to get new seals packed.
By all appearances, this looks to be a straightforward job. Two compression fittings to loosen to get the hydraulic lines off. Then a bolt and pin at both ends of the ram. Since I have never even seen the ram off the loader before, I cannot imagine if I need to elevate and block the bucket to get the ram at a proper angle for removal. Or, can all this be accomplished by simply tilting the bucket and keeping it on the ground? What other challenges might I encounter?
Sorry for the newbie questions, but, for me, things never seem to be simple, except for my level of understanding!
Thanks for any advice.
