We have our grass hay custom cut, raked,and baled into large round bales at about 1350 lb each.. This year, the bales I have seem to be loose on the ouside part of the bale and really tight on the inside. I believe the bales are 5 x 5 and the baler was a 565 John Deere, I believe.
I use a bale spinner to feed and it seems that a quarter turn of the spinner drops about the first foot of the bale off because it so loose. When I get to about the three foot diameter point the hay is so tight I have to get off the tractor and peel it so it comes off. I've tried mounting it on the spear off center so that there is a bit of an unbalance to help get it off where the bale is tight and that helps some times. I also bought some alfalfa/grass hay that was put up by another operator into 1100 lb bales but again using a JD round baler. These bales have the same characteristics regarding tightness/loosness.
The year before, the guy that baled our hay used an older NH chain bailer and his bales were more uniform.
My question is: Is this half loose/half tight bale typical of the John Deere balers or has the operator done something incorrectly to cause this to happen? If he has, what's he doing to cause this?
Thanks in advance.
Thanks in advance.
