Bush hog gear box run empty
ordel1
11-18-2008 17:32:43
There is a brand new bush hog for sale that apparently was not filled with grease when sold. Would anyone guess what would be involved with rebuilding the box. I do not know how long it was run before they realized it. They said it is not locked up.
Handsome Jim
12-25-2008 18:51:50
 Re: Bush hog gear box run empty in reply to ordel1, 11-18-2008 17:32:43
90w
Handsome Jim
12-25-2008 18:51:49
90w
Handsome Jim
12-25-2008 18:51:03
90w
Handsome Jim
12-25-2008 18:51:02
90w
charles todd
11-22-2008 19:25:21
Charles D Todd II, born and raised in Elmer. Currently live in Natchitoches. Father is Charles "Donnie" Todd, Grandfather was Charlie, RIP. And you are...
Charles
RobMD
11-21-2008 17:53:14
Put grease in it and try it first.
Crem
11-19-2008 20:21:10
I bought a new King Kutter rotary mower about 8 years ago. I knew that I needed to put oil in the gearbox but I forgot anyway. I ran it for over a round in the field before I thought of it. I filled it up and it works perfect to this day. There must have been a little assembly oil in there that helped out.
buickanddeere
11-19-2008 05:22:07
If you feel any roughness at all when tuerning by hand. Or if any noise/vibration occurs at all while operational. Tear the gearbox down. You don"t want all that metal whirling without proper support, just 8ft away from yourself.
RickL
11-19-2008 04:26:50
thta nothing unusual at ALL.I assemble new stuff and majority of them gear boxes are all shipped empty,doesn't make any difference what its on. Turn the unit by hand.see what it does. If it turns okay and doesn't feel rough use some JD corn head gear box grease in it and go. I put that in all the old old units if they leak and customer does not want new seal kit use that grease instead and it will run for years.
DiyDave
11-19-2008 03:50:39
Add grease, run it till it smokes everything, put in a new gear box from agrisupply. Of course, it would be most helpful to make sure that they stock the right gearbox in the first place!
RickB
11-19-2008 02:51:08
 Price a box in reply to ordel1, 11-18-2008 17:32:43
Price a new gearbox as your worst case. Anything you save from that is gravy. You won't know for sure till you tear it down. A shaft could be welded to the bearings, gears can be junk. or, I've seen a set of seals and bearings fix them up fine. Some complete boxes are more cost effective than their guts.
BCnT
11-18-2008 22:41:51
spin it over by hand slow and feel for rough spots...i had same thing happen with a new BEE shredder...supposedly serviced and ready to go...i cut about 10 acres and had some twine get in under stump jumper...i pulled it out and thot about gear box...checked it...never had a drop in it from factory...filled it with 90 weight about 500 acres ago...still goin strong.
doug in illinois
11-18-2008 20:28:27
If not locked up, would fill with gear lube and see where it leaks out after running it. I have a JD "bush hog" that has had baler twine and WIRE wrapped around the spindle, the seal is compromised. It will get noisy if it starts getting low on 85-140. If not leaking excess, fill it and run. DOUG
johns48jdb
11-18-2008 20:19:12
just for grins look under the bottom to see if its coated with oil. could be a bad seal and all the oil leaked out. i can't imagine bush hog putting something out that didn't have oil in it, but s--- happens. i'm with the other guy. take the fill plug out and any inspection plates you can and looked to see how much blueing in there you can find.
135 Fan
11-19-2008 21:32:59
 Re: Bush hog gear box run empty in reply to johns48jdb, 11-18-2008 20:19:12
It's common to ship machines without oil to avoid leaking. A lot of dealers don't seem to think they should have to prep machines before they sell them. It must take money out of their pockets. Dave
charles todd
11-18-2008 17:40:07
At the very least, a full gasket and shim kit. All bearings should be replaced, hopefully that is all that was damaged. If the gear set has spalling or heat marks, then a gear set as well... May be cheaper to buy a new gear box if all the above is damaged. If you get it for $350 then buy a $400 gear box you have about $750 in it now. A new one (Bush Hog Squealer) will run $1100 - $1350... Look in to it and check back.
Charles
CRUSADER
11-22-2008 18:09:10
 Re: Bush hog gear box run empty in reply to charles todd, 11-18-2008 17:40:07
Charles, are you from or live in Louisianna? Do you have any relatives near Elmer?
