Hi everyone,
What do you think of this idea?
I have a 10hp Tecumseh vertical shaft engine, which has done about 50 hours since we bought it brand new about 5 years ago. I have been thinking, I could buy a 38-44" mower deck, and weld on brackets to connect to a 3 point linkage, and then use this behind my Ferguson TEA20.
How difficult would it be to adjust the height on this setup? Would I need to make a structure which skids along the ground, and then have the deck adjust its height from that? Or would the 3PL on the tractor do a good enough job? I still need to be able to lift it up off the ground, so putting wheels on it and dragging it along is not an option... is it?
This would be used for mowing, not slashing. I will get a PTO powered slasher for that.
Any input appreciated, thanks.
