JD #52 plow
Jud
09-27-2008 13:52:23
I am restoring a JD #52 plow and I need to know what size of tire is supposed to be on them. Anyone know?
Leroy
09-28-2008 21:19:10
 Re: JD #52 plow in reply to Jud, 09-27-2008 13:52:23
Most had the steel rims cut off and rim for rubber put on in the 50's and a 6:00 X 15" was the likely size but it could also have had a 6:70 X 15" also used as they were as close to the orignal steel wheel as possible. Depending n what junker car was setting around they might have used a 5:50 X 17" as well.
maark
09-27-2008 17:27:09
probably a 5.50x16"
Stan - Florida
09-27-2008 14:20:14
I'm no help, for sure. I have an original manual for a No. 51 and No. 52 plow, and there is no mention of rubber tires.
Stan
B-maniac
09-27-2008 19:22:24
 Re: JD #52 plow in reply to Stan - Florida, 09-27-2008 14:20:14
Stan , I'm not too sure the 52 ever came with rubber! It was an option on the later #4 plows , but I bet this 52 was fitted with rubber after the fact.
Stan - Florida
09-28-2008 05:00:03
 Re: JD #52 plow in reply to B-maniac, 09-27-2008 19:22:24
I took a look at the manual I mentioned, and it does ideed mention 24" wheels and 4" tires. No mention of anything like tire size other than that. I wonder if they were just a hard rubber cover on the wheel?
Stan
Stan - Florida
09-28-2008 04:30:11
I agree with you. We had a No. 51 plow that we got in 1943 and a No. 52 that we got in about 1947...neither had rubber tires.
Stan
dds
09-28-2008 17:06:33
 Re: JD #52 plow in reply to Stan - Florida, 09-28-2008 04:30:11
i was just looking at these plows and found this site
Stan - Florida
09-29-2008 04:01:32
 Re: JD #52 plow in reply to dds, 09-28-2008 17:06:33
dds,
Thanks for that info...I guess I'll have to change my thoughts about rubber tires on those plows.
Stan
