I've been unable to figure out what any of these implements are. They came with the property we own. We also have a 1941 JD sickle bar and a JD hay rake built between 1940 and 1946, so there was probably a dealer in the area around that time. We have a No. 7 IHC McCormick-Deering sickle also, not sure when those were made. Other than that I don't know much about the time frame they are from.
If there are any different views that would help with the identification let me know.
^I don't even know what exactly you would call this sort of implement, everyone I've talked to has either called it a furrower or a plow. I didn't recognize the symbols on it, but they look like a crescent moon, a six-pointed star, and a triangle? It also has some gray paint on it. The yellow paint on it was because I messed up and accidently got it was some JD yellow when working a rim, so ignore that.
^Again, not sure what to call it exactly, but more people have been referring to it as a ditcher, so that's what I've been going with. It has some traces of green paint, so I was thinking maybe JD? I haven't seen any Oliver equipment in the area.
^This disc also has traces of green paint. If I would have been thinking I would have gotten a good top view picture, but it's out in a field right now so I'll have to wait a while for one. Also, would this be used for plowing or harrowing?
^This is an IH harrow. There is another identical section to it, but it wasn't handy. The wood has traces of what seems to be blue paint. The bolts between the teeth have cream paint and the rest has red, blue, and green. The number on the teeth reads:
450
704
R2
450
704
R2
