I see you're getting a lot of flack over cutting the disc down. There's things to consider that might not be taken into account by some of these guys. One, a TO35/MF35 might handle an 8' disc on fairly level ground, good soil, ect. Around these parts, put an 8' disc behind a 35 and you might as well have a couple boat anchors hooked to it. Tractor weight and traction are the reasons. Power is more of a minor consideration. My MF150 dynos at 47 hp. It's weight is approx. 5500 lbs. That's more power and more weight than a typical 35. It's got new tires. That 8'-10" MF disc was no issue on level ground. When I started discing a hilly piece of clay ground I own, it would slowly start spinning until it almost came to a stop as I went up a few hills. After removing one disc per gang, she pulls like there's nothing back there on the same ground. There is a good arguement for selling that disc and buying another smaller one. Sounds like a plan. But. You KNOW what you have with the one you've got. It appears to be a good solid disc. Who knows what or when you'll find another one as good, only smaller. In recent years, with all the "ranchette" farmers, food plot growers, ect, small implements sell better than big stuff in many cases. It's not far fetched to imagine paying MORE for a 6' or 7' disc than you can sell an 8'er for. So, I'd try what you have. If it works, go with what you know. If your tractor struggles with that 8'er, you might take a quick look around to see what's available in a smaller disc, but it sure won't be the end of the known world if you decide to cut that one down a bit. Cutting a disc down is simple, inexpensive, and you end up with a few spare parts. And... It's as simple as getting new longer axles to turn one into a BIGGER disc if that ever becomes an issue.
