10' International disk drawing of the part!!!!!!!
RichG
07-21-2008 19:03:55
third party image
The parts that I am looking for are #5 and #6. Any help about where I might find these would be great. Case has them for $110 for each section whick is way to high. I need three of each.
Gwiz
07-22-2008 18:15:50
 Re: 10' International disk drawing of the part!!!!!!! in reply to RichG, 07-21-2008 19:03:55
I should not have looked at this post. I just recently drug an old pull type disk out of a trash pile and cut off one of the end washers to see if it matched the one on my IH #37. It matched perfectly! However, I noticed it had the type of bushings you are showing. Sorry, I scrapped what was left of it. Some of those were broken, but I bet at least one of them would have been good.
I hate to see so much good stuff go, but at $190
a ton, its hard to resist.
James
K-Mo
07-22-2008 05:06:40
Try Agri-supply 1-800-345-0169
K-Mo
Hugh MacKay
07-22-2008 02:18:02
Rich: Convert it to the type of bearing Mike has shown you in the old thread. Good bearing stores can get those in any configuration you need. If I were doing it, I'd convert both front gangs then save left over parts for spares on back gangs.
It's been awhile since I've bought disk bearings, probably run you $50. each by now.
