346 feeding problems
JM in Merit
07-20-2008 15:36:12
I and also a friend of mine have a 346, Baler does great except when we try to bale long stem stuff like hay grazer or johnson grass. The hay goes underneath the auger and the auger just rides up on the hay. If we are in mixed hay, it does ok, but long stem hay it gives us problem.
Everything else does great on the baler.
Any ideas or suggestions
Thanks
JM
JM in Merit
07-21-2008 07:25:12
 Re: 346 feeding problems in reply to JM in Merit, 07-20-2008 15:36:12
Tx Jim, yes the belts are tight, the auger does not slip it will just ride up on tight of the hay. Just does this in stemy hay, other hay it will work perfect.
Tx Jim
07-21-2008 03:23:45
 Re: 346 feeding problems in reply to Randy-IA, 07-20-2008 15:36:12
Is drive belt tight? I've seen where 1/2"/5/8 " lock washers were driven on the auger flights at the split in LW to add some traction for feeding problems.
Roger in Iowa
07-21-2008 16:51:05
 Re: 346 feeding problems in reply to Tx Jim, 07-21-2008 03:23:45
It helps if the crop has been thru a mower conditioner as it breaks up the stems. The long sticks do not like to feed well, even in some round balers.
