ford flex wing mower clutch
cjs1958
06-24-2008 14:38:41
I need to get some new clutch discs on PTO drive for my ford 957 mower.This was made by BMB in the 80s. The discs are 6" diameter with 3 1/2" hole in middle. Can't tell the thickness probably 1/8" or 3/16". Anyone know a good source for these? Thanks.
cjs1958
06-25-2008 06:33:41
 Re: ford flex wing mower clutch in reply to cjs1958, 06-24-2008 14:38:41
Thanks for the info. My mower has 3 clutch packs, 1 main and two on wings. They all have 4 discs in them, and all discs are same diameter. I just checked with NH dealer they wanted $27 each for disc x12. Does that price sound right? Thanks
RickB
06-24-2008 15:13:44
You can get them by part number from Alamo or New Holland, depending on which discs you need. New Holland p/n 279434 fits the 4 disc clutch used 03/84 through 01/90. This would be the only clutch on that machine. The same disc (279434) fits the wing slip clutches on later machines with three slipclutches. The main clutch on later machines uses four discs, p/n 8939 from an Alamo dealer. The parts info I used does not have any dimensional data, but I hope this helps.
